Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang V6 1994 to 2004: Engine Noise Diagnostic Guide
Guide to diagnose trouble and recommended solutions
2000 V6 ticking noise from engine.
Hi, just bought a 2000 V6 Mustang and now notice a faint ticking noise coming from the driver side of the engine area. From my experience in the past, I'm thinking it is an exhaust leak. I know its pretty tough to diagnose this on-line, but what do you guys think that know these engines?
And if so, what is the fix?
Thanks,
Chris.
Thanks,
Chris.
Thanks,
Chris.
Thanks,
Chris.
Most of the exhaust leaks on the 99-04 v6's are from the passenger side since the condenser's drain tube is right above the exhaust manifold weld joint where the y-pipe connects.
Odd that yours is on the drivers side.
I'd still guess the same thing Where all three exhaust ports go into one on the manifold side, that mounting ring is probably cracked at the weld.
My 2002 3.8l would tick, from the driver's side, for 15-30 seconds on first start of the day and also after it sat for as little as 45 minutes. Mine was the manifold. I had a shop remove the manifold, weld it up, re-install with a new gasket, and the tick is gone!
Al
Al
