best aftermarket turbo.
Old 08-19-2008, 03:08 AM
hillbilly pony
hillbilly pony's Avatar
Default best aftermarket turbo.
Im looking for a streetable car and i wanted to get you opinion on the best after market turbo. OR is stock good enough.
hillbilly pony is offline
Old 08-19-2008, 05:35 AM
Boost Gobbler
Boost Gobbler's Avatar
is this for that engine build up your trying to do? if its simply a daily driver teh stock one will work fine if its in good shape. mine wasnt when i got mine so i saved up for s new one. i got mine from hahn racecraft, it has a year waranty new and is upgradable.
Boost Gobbler is offline
Old 08-19-2008, 04:38 PM
icelandismine
icelandismine's Avatar
A Holset HY35 or HX35 will work, and from what I hear, are quite nice. Not terribly expensive either.
icelandismine is offline
Old 08-19-2008, 05:13 PM
hillbilly pony
Im looking at a HX35 and an HX40 right now.. It does seem that most people are using that as an upgrade.
Old 08-19-2008, 05:15 PM
hillbilly pony
Probably gonna do a head stud kit and a main stud with strap kit and JE pistons and chromoly rods...anyone have any idea what boost that could handle.....which brings to mind do folks "o"ring the block and heads for high boost or is there a gasket that can handle ther high boost.
Old 08-19-2008, 05:40 PM
icelandismine
the holset will handle plenty of boost, more then you'll ever need for anything streetable. I've heard the Merkur and early TC T3 turbo's can handle a bit over 20 pounds, which is quite nifty too.
The rods are the weakest point in the engine, followed by the pistons...the crank is pretty solid. I am sort of curious about o-ringing the block too.
Your biggest hurdle in high boost is going to be fuel supply. If you want to run huge boost, you'll need huge injectors and a pump, and the stock computer won't take to different injectors too well.
Old 08-19-2008, 07:05 PM
sleeper_inc
sleeper_inc's Avatar
stock - 250hp
Stock .60/.63 T3 turbo
Modded - 250+
hybrid T4/T3
Holset
SC50
etc
Alot of people run 24+ PSI with good fuel.
The amount of boost depends on the timing, fuel, mods, etc.
You'll lean out the A/F without a 255 fuel pump and at least 46lph injectors.
sleeper_inc is offline
Old 08-19-2008, 08:25 PM
hillbilly pony
What is the most reliable Fuel management system and ignition control for something with say 350+ im used to MSD and such i have no real experience with turbo timing and fuel injector management etc??
Old 08-20-2008, 12:44 AM
sleeper_inc
350hp
stage 2 bo-port port job with larger valves
Holset Hy35
stinger header/bobs log manifold
2277 cam or a bo-port stage 1/2 or a RR cam retarded 4*
Boost (20+) and 12* timing
52-64 lph injectors
J3 chip
good intercooler
3" exhaust
Stage 3+ from spec (clutch)
etc etc
Check out the proven combo's thread on TF in the off topic section
Old 08-20-2008, 12:49 AM
hillbilly pony
I was looking at that....ist pretty impressive. my question is what is a j3 chip i havent found anything about that at all. is it a piggy back to a particular computer or what. if so which computers is it best with?? you seem to be the man here so just a couple of quick questions...are the 1.85 valve sets the best to go with and a i assume that 2277 cam is a roller?? does that need different springs or are stockers GTG. I have seeen some people running MAF setups...lightning inparticular seems to make sence since they are SOOO much bigger than any VAM. Also is a stock Throttle body good enough??
not much traffic here so i really appreciate all your inputs
Quick Reply: best aftermarket turbo.
