Replacing the A4LD Vacuum Modulator
Old 03-20-2008, 08:42 PM
sleeper_inc
sleeper_inc's Avatar
Default Replacing the A4LD Vacuum Modulator
If your Modulator has failed (like mine) then when you take the vacuum line off transmission fluid will drip out (flow out)
Loosen the bolt (its 10MM) and take the bracket out
Old modulator on the right, new one of the left
This is the thin metal pin inside the modulator... DO NOT LOOSE THIS!!!! transfer over to the new modulator
Pictures of the only modulator
Picture of the new modulator
Bracket used to hold the modulator in place
Space were the modulator goes
New modulator in place with vacuum line hooked up
not so hard to do when the car is jacked up
sleeper_inc is offline
Old 03-20-2008, 09:32 PM
924banger
924banger's Avatar
Default RE: Replacing the A4LD Vacuum Modulator
What are the symptoms of this failing? nice pics by the way!
924banger is offline
Old 03-20-2008, 09:39 PM
sleeper_inc
Later shifts, transmission fluid in the lines, and a wired burning smell (also bad shifts)
Old 03-20-2008, 09:58 PM
924banger
924banger's Avatar
cool, just asking for later viewers of this thread. It should be put in the tech articles.
Old 03-20-2008, 10:07 PM
sleeper_inc
Already there
Don't have the contributor badge for nothing [8D]
Old 03-21-2008, 05:03 AM
usermst9673
usermst9673's Avatar
how much did it cost you for the new one? And where did you buy it at?
usermst9673 is offline
Old 03-21-2008, 08:40 AM
sleeper_inc
$15, and I got mine from auto parts plus. Any store should carrie it
Old 03-21-2008, 09:55 PM
usermst9673
checked mine today and it was leaking badly. So i replaced it and figured i would change the filter and fluid in the tranny also. Well come to find out my trans is out of a 90 mustang even though my mustang is a 91. Drove nearly clear across town to the parts store that had the 91 filter to find out it didnt fit F*** me. Should have double checked.
Sleeper does your new one have an adjustment screw on it?
Old 03-22-2008, 06:43 AM
sleeper_inc
Yes it does, but thats because its the turbo one (highly recomend it since you can change your shift points with it)
Old 03-22-2008, 07:35 PM
usermst9673
good thats the one i got glad to hear i can adjust my shift points now!!!!
Quick Reply: Replacing the A4LD Vacuum Modulator
