4 cylinder to v8 Swap
Old 03-13-2007, 03:46 PM
  #31
1986_stang
1986_stang's Avatar
Default RE: 4 cylinder to v8 Swap
I have a carburator on mine so would I need to change the fuel pump when I upgrade to a 5.0
1986_stang is offline
Old 03-13-2007, 05:17 PM
  #32
foxmagic91
foxmagic91's Avatar
Im looking at dropping in a carbed 302 out of an old crown vic. Would the parts like the motor mount and trans mounts be the same? Also would an AOD trans bolt up to the older block or would i have to mod the tunnel for the C-6 ( i think ) that came with the motor.
foxmagic91 is offline
Old 04-01-2007, 04:57 PM
  #33
sleeper_inc
sleeper_inc's Avatar
Some one sticky this damng thing!!!
sleeper_inc is offline
Old 09-21-2007, 04:30 AM
  #34
mostdef
mostdef's Avatar
i have an 87 4 banger that i just converted...everything is going well and its just about done..i put in an 89 maf harness due to the 87 not having air bags...i was just wondering if everything plugs in good and if u had any problems with the wiring...or if u know of any site that may help thanks agin
mostdef is offline
Old 09-26-2007, 05:50 PM
  #35
samstigg
samstigg's Avatar
Ryan you said you changed the Radiator ....why? I was always told that the 2.3 and the 5.0 radiators were the same. I know a 3 row one was equipped in some.
samstigg is offline
Old 09-26-2007, 06:13 PM
  #36
Boost Gobbler
Boost Gobbler's Avatar
no offence but wouldnt this be more suited for a 5.0 or some v8 section?
Boost Gobbler is offline
Old 09-26-2007, 07:59 PM
  #37
sleeper_inc
No it wouldn't be, because most of the 2.3 people come here first thinking it will be posted every where. Unlike other parts of the forums we think its ok for the odd post to make its way in here that has nothing to do with a 4 banger stang
GimpyHSHS
19
12-19-2023 01:12 PM
TheGmKiller331
08-10-2009 10:04 AM
85four2eight
12-04-2005 09:38 PM
CarNutCass
11-10-2005 07:09 PM
TheGmKiller331
02-26-2004 12:38 AM
Quick Reply: 4 cylinder to v8 Swap
