well technically it does consist of the MAF. It measures the air coming in to send a signal to the fuel gods of how much dino juice to pump in to make the burn happen.
__________________
01 Bullitt #4630 Novi2000, A-A intercooler, 42# injectors, Xpipe, short shifter, more to come.
You don't need a new MAF (unless it's pegging) to run larger injectors; setting the high and low injector slope scalars to match the injector capacity is the proper way of doing it.
Also, larger "calibrated" MAFs are a kludge (all they do is lie to the PCM about the amount of air) that can really screw up the PCM's load calculations and everything else that depends on load numbers.
The proper way to use a larger MAF is to program the new units transfer function into your tune. They (calibrated MAFs) are a left-over from the days when ECU couldn't be reprogammed and you had to trick it...
__________________
-cliff knight- My Mustang
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper tuned
3.73s, 262 rwHP/305 ft.lb.
Multi-fuel: burns gas and rubber...
That's nice, but he said STOCK
Not professionally tuned, calibrated, etc...
Unless the TS has subliminal messages I'm not getting...
It was a simple question about stock capabilities, and people come in talkin about pumps, injectors, MAFs... It just makes me laugh sometimes..
__________________ RESIDENT FORD TECH
98 Cobra ~ Exhaust/Gears/Pullies/Suspension ~ 12.9@107
