I got a 351W 74 block engine number D4** Was going to keep this for a spair block but my little brother might be buying a rolling chassis. I thought about making this 351W a 393 stroker. Is there any step by step build ups on this type of project? I bought the 351w for 150bucks fresh from a machine shop everything but pistons. I also bought a 302 from a 97 1/2 explorer for 150bucks gtp heads and gt40 intake. I was going to take the guts from the 302 put in the 351w. Were trying to build a complete motor for around 1grand to run mid 11's around 450hp. We will probably add a 351W victor jr intake with a 750 demon carb, and a 6somthing lift cam with long tube heads and 3 inch exhaust.
__________________
408W Pro Fogger
Sponsored Links
This ad is not displayed to registered members. Register your free account today and become a member on Mustang Forums!
Your not using a stock 302 crank and rod in a windsor block anytime soon. A 393 is nothing more than a 200 dollar 3.85 cast crank, stock 5.956 windsor rod and stock 1.600 compression height 302 piston. The 302 crank and rod is useless in a windsor build
uhh wheelliftpony , you have supposedly a badass 408 and such and dont know that the 302 and 351 w mains are different size for one and that the 302 is a 8.2 deck and 351 w a 9.480 and 9.5
I know that was kinda dumb question but thought I'd ask anyway. I for some reason though you could use 302 crank n pistons with 351 rods. Wasn't thinking I guess. And my 408 build is close to being done. A guys supposed to call me back from florida has a set of 225 afr heads. That's all I need for the motor. I also decided to go with a power glide and a 2peice converter. Ill get more pics when the motors complete. And I never said I know it all we all screw up questions everyonce n a while. But tanks
I haven't looked but where can I pick up the crank for $200? I just might build me a 393 quicker than I thought.
So a 351w block doesnt need to machined to make a 393? Does fordstrokers sell this rotating assembly?
