Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-07-2008, 10:58 AM   #1
ym42
ym42's Avatar
Cool Passenger Side Water Leak (inside the cabin )
I was seating in my parked GT'06 vert yesterday, right when the Hanna was passing over. ( for those not living on this coast - that was the storm here, with a lot of heavy rain and wind). The rain was very heavy, and I decided to park in a different spot, closer to the entrance. As I started moving the car I heard/saw the water leaking heavily onto the passenger side floor mat. I went under there and looked where its coming from, and it was coming right from the box that is next to the fan, the box that look sort of like an air filter housing. There is an orange wire there on the housing and the water was leaking around it like from a hose, about 2 quarts alltogether... I guess it happened because the car tilted slightly differently when I reparked it. But I am sure it is not supposed to happen like that. Any help?
__________________
'06 Mustang GT Convertible
5 Speed Manual
Front Strut Brace
50k miles
ym42 is offline   Reply With Quote
Old 09-07-2008, 11:26 AM   #2
deekum1627
deekum1627's Avatar
Vehicle: 2008 Mustang GT
Send a message via AIM to deekum1627
that might help alot of other ppl tring to find there leak thanks for the info, so what you goin to bring it to ford to get it fixed now, o and i had hanna pass over hear on long island where are you from
__________________
looks- roush spoiler/cdc aggressive chin/blackout panel/shorty ant/3d carbon grille/sequentail tail lights,steeda strut bar,
performance- full mac exhaust/ mgw shifter/che k-member w/tq limiters/ C&L racer and x3 brenspeed tune/ frpp 4:10s
waiting to go on:eibach pro springs, koni STR.T shocks and struts
YANKEES WORLD CHAMPS #27
deekum1627 is offline   Reply With Quote
Old 09-07-2008, 12:19 PM   #3
MalibuJerry350
You, more than likely, have a clogged cowl drain. Very common problem. The clogged drain won't allow the water to drain and it backs up through the cabin filter and flows (literally!) into the passenger compartment. Remove the passenger side of the cowl cover (the little push pins holding it down need to be removed....do a search for Cabin Filter replacement) first. After the cover is removed, you will see the cabin filter mounted against the firewall. That is where the water enters the cabin. If there is any debris, leaves, pine needles, etc, in the cowl "tub" remove them first. Then, clean out the drain. It is located under the cowl on the passenger side....a little rubber boot, if you will. I used a small wooden dowel to clean mine out. Run some water from a garden hose to completely flush out any remaining debris. Because of the many trees on my property, I have to check my cowl drain at least once a month in the fall. Hope this helps.
__________________
2006 Mustang GT Tungsten Grey Metallic
57 Chevy Belair
70 Chevelle, original owner with 676,000 miles on clock!
MalibuJerry350 is offline   Reply With Quote
Old 09-07-2008, 01:25 PM   #4
ym42
ym42's Avatar
Thank you. I will try to do that...
__________________
5 Speed Manual
Front Strut Brace
50k miles
Old 09-07-2008, 05:43 PM   #5
ym42
ym42's Avatar
OK, it was REAL EASY to fix. I read the instructions about the cabin air filter, went outside and took it out. The rubber drain part was completely blocked with all sort of crap, but was really easy to get out and clean. The air filter was quite dirty too. This was the easiest thing to do after all.
Instructions:
Turn the ignition on and use the wiper lever to position the windshield wipers in a straight high vertical position. Turn off the ignition. Open the hood, use the + screwdriver to remove the fasteners holding the plastic cover ( passenger side only, part that touches the windshield ) - it slides towards the front of the car under the hood and towards the drivers side. Under there there is a filter, and after you take it off you see the oval elongated rubber drain part. Use your right hand and pull it out from under, putting your hand between the engine cover and the battery. Clean it and put it back from above, through the space where the filter was. Easy! No more leaks!!!
__________________
5 Speed Manual
Front Strut Brace
50k miles
Old 09-07-2008, 05:46 PM   #6
StickShifty
2008 Ford Mustang
StickShifty's Avatar
Vehicle: 2008 GT/CS
Send a message via AIM to StickShifty
good to hear everything is ok.
mine was outside as Hanna passed yesterday, no leaks, trees, damage...!!
__________________
2008 Performance White GT/CS - Build Date: 2/15/2008 - Tuned by Brenspeed/C&L Intake/SCT Tuner/Corsa/FRPP Springs/Tokico Shocks/BMR Strut Brace /BMR LCAs/BMR Brackets/Steeda Pan. Bar/FRPP Cam Covers/Bullitt Grille w/ Tri-Bar Pony/8" Shorty Antenna/Hood Struts/CS Stripe Delete/Clear Corners/White Shift Ball w/ Grabber Pony Collar/Sat Radio/S2000 Start Button/Altec Front Plate Mount
StickShifty is offline   Reply With Quote
Old 09-07-2008, 06:14 PM   #7
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
If it wasn't that then I'd say that you need to read the Water Leak TSB.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is offline   Reply With Quote
Old 09-07-2008, 06:24 PM   #8
Stndbck
Stndbck's Avatar
Vehicle: 2007 Mustang GT
Mine was outside , under it's cover during what was Hanna passing over.....The cover actually stayed put even though it was pretty blustery.
I think we all are lucky that the storm was not as bad as the media predicted it would be, at least in the NJ area.
__________________
Vista Blue GT LOVE IT! It's bone stock -- except for the shorty 'tenna and the polished billet plug in the power outlet. Keeping it that way too.
Stndbck is offline   Reply With Quote
Old 09-07-2008, 07:54 PM   #9
HypromanGT
Quote:
Yep, you may not be out of the woods yet, trust me (check my sig :-().
Get your hands on TSB 07-14-6 and be sure to keep checking your passenger floorbards after a rain, carwash, etc. The first time my 06 leaked, the dealer came back with the same fix as you have done, only it kept leaking! After some electrical craziness, 5 more fix attempts later, including brand new carpetting, pulling and resealing the windshield, and they never did fix it.
Good Luck...
__________________
-- 2008 Alloy Metallic Mustang GT Premium --
Ford replaced: 2006 Tungsten Grey Mustang GT Premium (Water Leak Edition)
HypromanGT is offline   Reply With Quote
Old 09-07-2008, 09:20 PM   #10
Lifter583
Lifter583's Avatar
Vehicle: 06 Black GT
I cut the ends off those damn grommets. Now they dont restrict the water and gunk.
Lifter583 is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
